Zenfone 7 scheduled charging issues
DesuraBuritzu
When I activate the option, and set it from 16:00 to 7:00 (next morning), I get notification that says "Dynamic charging will be activated from 13:05 to 21:00". I don't know why it doesn't work. Also when I activate slow charging, get the notification about it being activated and turn off the phone, when I click the powerbutton to see it's battery state, it says "hypercharge".
4 REPLIES 4
DesuraBuritzu
Also sometimes it just doesn't activate even though it is activated in settings.
CVonC
Rising Star II
Hmm mine seems to be working no probs
AmitGarde
Community Legend II
DesuraBuritzu
Try to factory data reset your device & your problem will get fixed.
Go to settings>system>reset options>erase all data
Remember before performing Factory data reset please dont forget to backup your important data as it will erase everything.
I can assure you this because i use to face this same problem with my Zenfone 5z for scheduled charging and that only got fixed after factory reset.
Anders_ASUS
Hall of Fame III
DesuraBuritzu
you need to clear the storage of your power master app
