03-21-2021 04:16 PM
04-01-2021 04:53 PM
fear_dot_com_2000My device does that too, so it's a general thing, I hope that with the next update asus can fix thisHere is an example video. As I said always on 90Hz, opened google maos, each time a press the navigation pill the color switches to a blueish tint. After releasing the pill back to normal. Sometimes it happens also on chrome , but by simply opening it and not pressing anythign
https://us.v-cdn.net/6031231/uploads/9FMMM31MT8TV/vid-20210329-wa0001.mp4
04-13-2021 03:05 PM
fear_dot_com_2000Here is an example video. As I said always on 90Hz, opened google maos, each time a press the navigation pill the color switches to a blueish tint. After releasing the pill back to normal. Sometimes it happens also on chrome , but by simply opening it and not pressing anythign
dorianmariocroitoruMine is different than the other thread. Looks like a greenish gradient going from the top of the screen when using 90 Hz.https://zentalk.asus.com/en/discussion/comment/160429#Comment_160429
04-14-2021 11:57 AM
04-14-2021 02:00 PM
fear_dot_com_2000Just had the A11 update today and it's not better. I also tried just a grey image and it's the same as in the apps. I think I'll have to send it in and hope for the best.That greenish tint is somehow normal on ZF7. Most of the user have it and it can be only seen with dark android themes. ( There were a lot if posts here about it and @Anders_ASUS said that it was normal on samsung panels, but if you think it is too much you can send your device in service for checks...).
I actually think it is a combination of panel and android cause if you open a black picture on full screen you will not notice any green. At least for me it is so...but if I open any black screen from android (like messages or discovery panel) I also see it. So I don't think it will ve fixed. A good thing is that I think google calibrated it on A11 since I didn't notice it that much on A11 update...
Hope this helps you!
04-21-2021 11:07 AM
