Bluetooth devices not displaying battery level after Android 12 upgrade
wirazo
Hi, I have a Zenfone 7 Pro which was updated with new Android 12 just 2 days ago, I use different bluetooth earbuds for music and to receive calls, before the udate those gadgets displayed their battery level when paired, however, after the update there is no battery indicator in the notification bar. What I was doing to tackle this, is to disable calls (within bluetooth device options) and re-enable it again, then, it shows up, but when I turn off the earbuds and turn on again, the battery indicator is missing again. Any solution?
ASUS_Bot
Rising Star II
