Android 11 installation (Zenfone 7 Pro)
Pupino
Model Name: Zenfone 7 Pro
Firmware Version 30.40.30.96
Hello everyone,
I did the installation of Android 11, but I was surprised by one thing in particular and I
hope it is not a mistake: it took very little to update! Let me explain ... usually a major
update takes place with the robot and the line loading and at least 5 or 6 minutes,
while in this case (separate download) the installation lasted perhaps less than a minute!
It's possible? Was it the same for others?
Thanks to those who will help me.
Anders_ASUS
Hall of Fame III
Pupino
  1. Model Name: Zenfone 7 Pro
  2. Firmware Version 30.40.30.96
Hello everyone,
The robot animation is not used any more. The update process is more seamless and fast. It might have felt like it took less than a minute but the only thing you need to check is if you have the latest fw version.
If you want a super clean install, then I recommend you to downgrade to Android 10 and then upgrade to A11 again. This will wipe and update everything. Not just some of the files.
