[Zenfone 6] [Solved]No difference in sound after turning on outdoor mode.
yashtr
After getting the lates update (as of Jan 3 2020 .110) I can see no difference in sound after turning on the outdoor mode. Can someone confirm this?
yashtr
No difference in sound even in safe mode
evnchn
Rising Star II
From my observations, outdoor mode reduces bass so that it can allocate more to other frequencies.
Theres no way you can't feel the difference. Try playing it with mode on and off, with mode on you physically feel the phone vibrate less due to less bass
yashtr
I tried factory reset (twice) without any success. I reset it the third time without restoring my apps and settings and everything worked like a charm. Also thanks for your help. I am marking it solved.
evnchn
https://youtu.be/e05NioB8wuo
