Vibration on notification is too strong
Giorgio80
Vibration when receiving a notification is too strong even in low setting (the phone "makes" a bad noise when laying on a surface) . It could be also helpful if one can also set the vibration pattern.
9 REPLIES 9
Giorgio80
Vibration intensity can be adjusted for Incoming calls, Notifications and Touch vibration. Look for the option "Vibration Intensity" in "Sound" Setting.
As i said initally, vibration is too strong even at low setting
ptsena
Note too, I agree. Also, there is a certain need for balanced adjustment between a low or high message, the lack of middle ground.
m4n15h_r4w4t
Rising Star I
Seems fine for me but I have disabled it due to camera module buzzing.
Giorgio80
Is it possible to add more intensity levels? Now you can set only one of 3.
Anders_ASUS
Hall of Fame III
I have asked our software team to fix this. Thanks for your feedback!
