12-29-2020 03:33 AM
12-30-2020 07:58 AM
ScoooYeah I'm using the same device and facing no speaker issue I think it is better you make sometime and contact service centerhttps://zentalk.asus.com/en/discussion/comment/143584#Comment_143584
Well, I have tried it, it doesn't work. Also, the nearest Asus center is actually not near to my home and given my current schedule it is not going to be possible for me to visit it either. Moreover, I do not think that this is a hardware issue as the speaker does work loudly like for a few seconds, it just does not sustain it. I highly doubt having the speaker or the module change will have any effect, but I guess I can't keep wasting my time looking for solutions where there aren't any.
Thanks for help still, any other solutions will be highly appreciated. Also, if you're using the same device, you're not facing any such issue, right??
Thanks,
Scooo
12-31-2020 03:32 AM
Raghu B RSo a quick update: There's some good news!https://zentalk.asus.com/en/discussion/comment/143653#Comment_143653
01-01-2021 03:15 AM
ScoooAs I said you to verify was that a smart volume issue congratulations on your device going back Normalhttps://zentalk.asus.com/en/discussion/comment/143660#Comment_143660
I was never fully convinced that the problem is with the hardware, and it seems I was right.
I upgraded to A11 in hopes of having the issue resolved but the problem persisted. So after a lot of hesitation, I performed a factory reset, the issue still persisted. I then went on to toggle some audio features on/ off, and voila! The sound from the speakers was back to normal!! It fine now and the Outdoor Mode as well as AudioWizard is working fine.
I'm glad I spent some time myself at home instead of spending valuable resources on a trip to and from the service center.
So, thanks, in the end it was smart volume issue and something wrong with the balance between the top and the bottom speakers on stereo mode.
Thanks,
Scooo
01-01-2021 03:40 PM
Raghu B RThanks man, I wish I had tried a factory reset 2 months earlier, although I never really use the phone speaker to listen to music, it's important that I hear the phone ringing when I need to lol and the alarms should be loud enough to wake me up in the morning.https://zentalk.asus.com/en/discussion/comment/143895#Comment_143895
01-14-2021 04:14 AM
