When I try to use the sd card as a internal storage, I cannot find a way in asus 6z phone and I read a comment from here mentioned by
Anders_ASUS.
He said the policy is changed by google and it is not possible to use sd card as an internal storage in android pie os. However I see some YouTube contents which show it is still possible to use sd card as a internal storage even in the android pie os. It shows that this restriction of using sd card as an internal storage is decided by manufacturer not by google.
I don't know which is correct information but based on the above content, I doubt that asus intentionally restrict this by any reason and also know the way to fix it.
Many people think that they can use sd card as an internal storage(save and install app in sd card) when they choose the asus 6z phone.
I hope asus can find a good solution with this.
