Reboot crash and Wi-Fi connection
ferxo13
I read about this problem about the .167 update because my phone rebooted by itself without an advise when I was using normally, I bought the phone last week and it updated to the .174 update but today my phone updated to .189 and look for the problem because it wasn't normal for me to happened that and the Wi-Fi connection on my phone is "connected" but it takes a while to send a message, load, etc. I don't know if I have the same problem with the motherboard.
Here's the bug report :
https://drive.google.com/file/d/1-JneUjffgdYHs26Gr1HcdsPFLSu0QrNZ/view?usp=drivesdk
LP_ASUS
Community Legend I
So do you mean the phone only rebooted once, and not in an endless loop? That sounds like it might have just updated to the latest FW.
For the Wi-Fi issue, go to Settings > Network and internet > Wi-Fi > then the network you're having issues with. Tap forget network and re-enter your credentials. Let me know if that helps.
