Ram management and heating issue
adarshso761
I want to know that you are going too fix the Ram management problem or not
48 REPLIES 48
Sreekiran
Still there. Slightly better. Bu the battery is draining like hell after the latest update.
Asus, fix this please.
So you mean to say I shouldn't purchase this phone as everyone is talking about the bugs and problems faced by them?
Pls suggest me I don't want to waste my 32k
Sreekiran
I would suggest you to wait. If it is urgent, look elsewhere.
Sreekiran
Wait for what?
I am planning to buy on October.
Anders_ASUS
Hall of Fame III
I might be biased since I work for ASUS but I still haven't seen any proof of a widespread battery drain issue that some users like to talk about. You will have better battery life with ZenFone 6 than most other phone if they are all used in the exact same way.
If Sreekiran believe that he has a battery drain issue, then there's a simple test he can perform to find out if there is a hardware issue or if there is some app that's draining the battery. In this test, you simply needs to put your phone in flight mode without charging when you go to sleep. The battery loss shouldn't be more than 1% per hour of sleep. If you have lost more than that, then we can log your phone to find out why.
Sreekiran
Thanks for the info Anders. Will test it out and let you know.
