Questions around android 10 on zenfone 6
gouravjoshi100
Rising Star I
@Anders_ASUS @LP_ASUS @CH_ASUS
First things first...thanks for quick android 10 update. Asus has really done a good job and people who are complaining does not how difficult such update can be...they should understand firewares are not easy even pixel and iphones are not safe even though they are first party os and devices. I am not saying there is no issue..definetly it is not perfect but we need to give some time to Asus to fix issues.
Now second part
1) I saw tremendous performance and battery improvement after updating z6 to android 10 via flashing full file...i went back from android 10 to pie and again update via file option rather than ota and things are very smooth now compared to previous dont know why?...
2) Sometime Clear all button in recent apps do not appear. it is not all the time sometime let says 2 or 3 times it does not appear. can u please check.
3) UI is not clean like when u scroll up on all apps screen in setting. it overlap with status bar which is not a good experience instead all app bar selection bar should be fixed and nothing should appear after that..u can check oneplus 7. I saw such UI glitches in a lot places like similar issue with sms app but it overlaps with navigation bar...and a lot setting pages having this issue.
4) I bought z6 for camera, I know u guys are working when no new features are added since long. Z6 is flagship phone atleast for asus so we expect some more support and I hope u guys are working on new features as well apart part fixes performance of existing features. Any update u have?
5) I heard project mainline is available for zenfone 6 but is it correct? if it is then why we have not seen any play store update for November? sorry if there is no update released so far from google itself or asus need to enable it?
33 REPLIES 33
_jis_
Zen Master III
gouravjoshi100
https://zentalk.asus.com/en/discussion/comment/28679#Comment_28679
@CH_ASUS @LP_ASUS @Anders_ASUS @_jis_
steps to reproduce 2) issue of clear all button under recent apps
1) press recent app button and clear all apps.
2) open an app now and press home button on to exit from app DO NOT EXIT BY PRESSING BACK navigation button
3) press recent app navigation button and here u wmt see any clear all button
This scenario doesn't work for me. I still see Clear all in the step #3.
Tested with ASUS and Nova Prime launcher,
_jis_
Zen Master III
kooldude7285
anyone facing this issue
whenever pin is required for instead of finger print.. the screen won't light up with the finger print sensor.. you have to manually press power button and thn enter pin. usually fp should light up the screen with pin input screen..
Exactly, this bug was already discussed in this thread as #1, but it is still present even in A10.
See my first and third posts there.
https://zentalk.asus.com/en/discussion/11102/zenfone-6-feedback-and-questions
gouravjoshi100
Rising Star I
@_jis_ @skyler0225 u might be using some different launcher...i am using asus launcher
sivamani242
Rising Star I
skylerwolfe
https://zentalk.asus.com/en/discussion/comment/29231#Comment_29231
I just tried this and if I understand what you are saying, I did not get the same result. This is what I did (granted I am using Nova Launcher, maybe that matters)
  1. Hit recent button and cleared all apps. Upon hitting that button I was taken to my home screen.
  2. Opened Signal (my texting app).
  3. Hit the home button.
  4. Hit the recent button. This showed only the texting app and below it there was the "clear all" button visible.
I tried this again about 5 more times with different apps each time it worked the same way (correctly). If I misunderstood, my apologies. I am on the lastest WW android 10. I have done a reset of the device since the update (trying to fix another issue).
When you face any app preview freezed in all clear opition
Then open any other 2 to 3 apps then clear all,
For me this trick has worked fine
skylerwolfe
Zen Master I
gouravjoshi100
Yeah, I noted in my post that I use Nova launcher.
