pie firmware for the US Zenfone 6
shadavis08
Is there a pie firmware for the Zenfone 6 in the US I need to downgrade because I unlocked with Android Q on the phone and it's messed up my fingerprint sensor it doesn't work at all please help thank you.
9 REPLIES 9
shadavis08
So if this is true why does it say this?
"Version Android Q downgrade to Android P
2019/11/041.86 GBytes
ASUS ZenFone 6 ZS630KL Software downgrade from WW-17.1810.1910.63 (Android Q) to target Image Version: WW-16.1220.1909.194 (Android P) by using MicroSD card for WW SKU only* Please follow step 6 and ensure to backup data before downgrade.
Steps of Update:
1. Prepare a MicroSD card.
2. Check software version of your device**
3. Only apply to same SKU update, Example: WW->WW, CN->CN, TW->TW, ID->ID.
4. Software update cannot transfer the software SKU.
5. Wrong SKU may cause update failure, please update the same SKU version only.
6. How to manual update firmware please refer to"
This says downgrade from WW-17.1810.1910.63 To version WW-16.1220.1909.194. don't I need to be on firmware version WW-17.1810.1910.63 for this to work for my phone ?
shadavis08
LP_ASUS
I haven't tried to downgrade back to 9 with multiple versions of Android 10, that's why I noted it may not be possible with the most current version.
You won't lose access to any of the bands, that is a hardware function that doesn't fluctuate with firmware.
If the only thing you are worried about is the lack of a fingerprint sensor and are otherwise satisfied with Android 10, then I recommend backing up all of your data and performing a factory reset. The upgrade from Android 9 to 10 messed with the fingerprint features for many users, but was easily resolved with a factory reset.
It wasn't the update that did this. It was unlocking the bootloader while on Android Q . Unlocking while on Android Pie does not have this issue . So I need to get back to pie without bricking my phone lol
shadavis08
kikoly
https://zentalk.asus.com/en/discussion/comment/46290#Comment_46290
Any version of Android 10 is downgraded to Android 9 with the same firmware, even for future Android 10.
So it won't break my phone to use the downgrade zip on Asus website? Is that what you mean
kikoly
Hall of Fame II
shadavis08
https://zentalk.asus.com/en/discussion/comment/46292#Comment_46292
Downgrading will clear the data in the phone. Please make sure the data is copied first.
kikoly
Hall of Fame II
shadavis08
Steps of Update:
kikoly
目前官網無android 10的.63的韌體。
降版韌體可用在所有版本的android 10韌體降至android 9 的.194,不限定只適用於.63
Downgraded firmware can be used in all versions of Android 10 firmware down to Android 9.194, not limited to only .63
