11-23-2019 02:31 AM - last edited on 01-16-2024 02:02 AM by ZenBot
11-23-2019 03:07 AM
11-25-2019 02:46 AM
d.secciHolding long-press on the power button does not turn the phone on - I assume this is the problem you are facing?https://zentalk.asus.com/en/discussion/comment/29606#Comment_29606
Nope, no messages. Just the green charing status icon as it's in the picture in the opening message (but it looks like it's frozen).
11-30-2019 10:30 AM
CH_ASUS1) correct 2) nothing.https://zentalk.asus.com/en/discussion/comment/29607#Comment_29607
What happens if you long-press Power + Volume Up together?
12-02-2019 12:41 AM
d.secciGreat that the issue resolved itself.https://zentalk.asus.com/en/discussion/comment/30064#Comment_30064
Luckily the issue solved itself after almost 10 hours on the charger - I tried to switch it on and magically it was working; I was actually pressing all the buttons at once in a moment of desperation - not sure if that turned the phone on, or else. But it has been working fine ever since.
