One hand mode doesn't work with Android 10 gesture control
CbIP
Hi, Asus.
I have just noticed that "one hand mode" doesn't work with Android 10 gesture control. The one hand mode requires double click on the home button to activate/deactivate and the Android 10 gesture control doesn't have the home button.
Is it possible to re-map the one hand mode to another button/gesture?
superniiice
Hi CbIP,
Yes, that's true. But you can map the shortcut in the quick access menu (notification panel) as kinda workaround. That's how I've done it. Hope it helps.
Cheers
S
