No additional options after long press
prashanth
Rising Star II
When i long press an app no options are showing up like,edit or uninstall etc..it just takes as though i did a single tap and opens up the app
And also not able to open app preferences cause its gestue is also based on long presses in home screen
2019-11-19-16-56-43.mp4
anyone else face this issue???
Just for reference im posting a video
"I just did a factory reset 4 days ago due to UI lag after ans oid 10 update as suggested by mods" so resetting and restarting device every 3 days don't seem to be an option for me considering it to be a flagship @Anders_ASUS @LP_ASUS @CH_ASUS
10 REPLIES 10
Anders_ASUS
Hall of Fame III
You have to let go of the idea that a phone should never be restarted. I agree that a phone do normally not need to be restarted but it's not a rule by any means. You also like to experiment with theming apps and settings so in your case, I would say that it could be considered normal that you need to restart it once in a while. It will only take you seconds to restart your phone and you won't lose any data.
