DS4 controller not compatible with Android 10
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-20-2019
05:24 AM
- last edited on
01-16-2024
02:01 AM
by
ZenBot
Please dix the connection problem with DS4 controller,because the Sony remonte play App is compatible and work,but when i attempt to connect DS4 controller by USB,the controller don't work ,and if i connect by bluetooth (with the correct DS4 method), the controller is compatible with Android,but in the remote play App, a popup apair and Say that phone can't use the DS4 controller when the stream is active....so please this bug because it will be a Big feature for this phone!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-02-2019 12:21 AM
I'll ask someone internally to have a look at this. To see if it works, if it's supposed to work and if we can make it work.
Thanks!
Thanks!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-05-2019 05:51 AM
DualShock 4 not being compatible with Remote Play App for other devices - we are not sure is a bug or a restriction from SONY.
As they only mention DS4 + Remote Play app is only supported on Xperia and some other phone.
DS4 + Android, as a normal controller, does it also not work? (If we first ignore the Remote Play app).
