Camera retraction grinding gears sound??
off2fly115
Rising Star II
So I never noticed this still now but every time I press the camera retract button, the camera makes a few weird grinding gear sounds. Before, it used to sound smooth like it was just the motor but now it kinda sounds like something is grinding. Sometimes the sound is there and sometimes it sounds completely normal. The camera flipping mechanism works perfectly fine, but it was just something I was curious about to see if you guys could hear any similar noises? Let me know what you think and how your retract camera thing sounds! Thanks - best regards, Branden
LP_ASUS
Community Legend I
The camera motor noise sounds the same on my unit as the first time I used the phone. If your unit is making an obvious grinding noise that wan't present before, I recommend contacting Support for a warranty repair. This sounds like a hardware issue.
