12-11-2020 01:12 AM
12-11-2020 02:11 AM
12-11-2020 02:49 AM
victor0_ASUSI will share once my battery is at 10%. I always do keep an eye on background apps. As of now SOT is 1hr 20 mins from using Chrome and youtube battery is at 80% this used to be a lot better. Before I would've got the same SOT with a 11% drop not 20%. Also the problem is with first 20% battery drops quickly rest drains faster than before but not as fast as first 20%Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Please follow the below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
12-15-2020 12:50 AM
12-24-2020 09:31 AM
