WiFi auto connection
vojtan2003
Model: ZE620KL
RAM: 4G
Firmware/APP Version: Latest
Frequency of Occurrence: ...
Rooted: No
APP Name:
Screenshot: https://us.v-cdn.net/6031231/uploads/ww_attachments/201901/08/235631nj9ecjuevveclef8.jpg
Hi. When my phone finds public WiFi, it will automatically open a "login to WiFi" window. It's kinda annoying when I'm taking photos, texting... and It will pop up anytime, even when I don't want to connect to WiFi. It's possible to turn it off? (I'm also sending a screenshot of the app, that makes those login windows.) Thank you for any responses.
ServiceE_Asus
Hi vojtan2003, Good day. Please kindly go settings> connections> WiFi > 3 dots menu > WiFi advanced > turn off " Open network notification". Thank you. 🙂
vojtan2003
Emilee_ASUS posted on 2019/1/9 08:23 Hi vojtan2003, Good day.
I visited our support in Czechia and the answer was: "If you are offered with WiFi, then you can only influence this by turning off WiFi." So I really appreciate your help.
