Signal problem
rdlavarias07
My phone dont have signal i change my sim n everything still no signal
Y_ASUS
Zen Master I
Hi rdlavarias07, We would suggest that you try: (1.) Settings > Network & internet > SIM card> Disable and enable the SIM card (2.) Settings> Network & internet > Mobile network > Preferred network type> choose "2G/3G/4G" again. (3.) Power off your phone > reinsert sim card > turn on the phone (4.) Turn on airplane mode > wait for 3 seconds > then turn it off. (5.) Try using another sim card by a different operator (6.) Try resetting the network settings: Settings > System > Reset options > Reset WiFi, mobile & Bluetooth) (7.) Please make sure to update to the latest firmware version WW-16.0615.1910.112. If the problem still appears, please help us provide your carrier and screenshot of the error. Thank you 🙂
