Hi
CoconutthiefThank you for your asking. Do you mean that you are trying to perform the Factory Reset?
Please try the following steps to access recovery mode for the Factory Reset:
0. Try to back up your data with USB cable. If you can not access the phone, please check if your google account or microSD card have auto backup your data.
1. Power off the phone, then keep pressing "volume down key"
2. Press "power key" and stop press " power key" once you feel the vibration. Still keep pressing "volume down key".
3. Stop press "volume down key" once you enter [Android Recovery] Screen
4. Choose "Wipe data/factory reset">"Yes"
5. "Reboot system now"
#Hardware Reset Guide
https://www.asus.com/support/FAQ/1006346/Please note that once the steps are completed, all data, apps, settings and personal information will be deleted.
If the steps above still can not be performed, please bring your device to the nearest service center for further device checking.
https://www.asus.com/support/Service-Center-All-Countries/If it is impossible to access the service center during Covid-19 period, please try Call us:
https://www.asus.com/support/CallUs
