10-20-2020 08:56 PM - last edited on 01-16-2024 12:35 AM by ZenBot
10-20-2020 11:57 PM
Kuis KiskeI hope after this Asus can provide firmware to improve the volume sound of Asus Zenfone 5 ZE620KL which is too slow. Volume has lost by 50% after I upgraded to android Q and remains slow even though I have upgraded to android P again.
I bought Asus because of its sound quality.
Hope Asus cares about this.
Asus Zenfone 5 ZE620KL low volume
10-21-2020 01:32 AM
10-21-2020 02:34 AM
10-22-2020 10:40 AM
Christine_ASUSSo when will the stable version arrive? With this sound level, you have to increase the quality even more and improve the camera. The camera and sound are very bad. For this reason, we cannot use A10 properly even with different rom files. A10 to Zenfone 5 You have a promise and do not keep your word. I know you won't even answer that. I have only one question. Are you not ashamed of not giving us the stable update by promising 2 updates?Hi eirinn1975
Thank you for your asking. The user who asking the issue above are facing the low volume in both Android 9 and Android 10 beta, so I suggest him/her to visit the service center. For your case, can you provide me an accurate number of the volume difference between the two firmware version? I just tested two devices, one in Android 9 V131 and one in Android 10 beta V25, the two devices were set in volume 50% with earphones, and the volume difference I can notice 5% lower in Android 10 beta V25. I suggest it is a normal behavior of Android 10 AOSP system.
