Inverted screen and sound problem
p4n6ky
Model: ZS600KL
RAM: 4G
Firmware/APP Version: Pie 9.0
Frequency of Occurrence: Always
Rooted: No
APP Name: Games
Hello ASUS, Do you aware of this problem? 1. Inverted screen. Try play any game, suddenly, the screen is rotated by itself 180 degrees. I tried with MLBB and PES2019. TRY IT URSELF. 2. Sound is rubbish. No need to provide proof. Try it yourself, I'm sure you have the phone. Try the one with old rom, compare it with new rom. Granted, you delivered PIE, but please fix this.
roshanghafori
Disable auto rotate screen from ur notification bar
p4n6ky
I always disable auto rotate. Not helping.
Ichal
If you root acces use dolby digital plus, bass effect normal again
