5Z Update to Android 10 - a couple of little problems s...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-30-2019
09:11 AM
- last edited on
01-16-2024
01:40 AM
by
ZenBot
Model: ZE620KL
RAM: 6G
Firmware/APP Version: ww_100_04.44.98_20191115
Frequency of Occurrence: once
Rooted: No
APP Name:
Last edited by srota on 2019/12/1 12:20 5Z Update to Android 10 - overall good results, a couple of little problems solved. Just to share some findings , in case other users will encounter the same little problems. I updated the phone downloading the Android 10 version ww.100.04.44.98 from the AsusTek web link: https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZS620KL/UL-Z01R-WW-100.04.44.98-user.zip The updating process went smooth. Problem with Contacts: when the phone restarted I noted that opening the contacts, names and addresses were not visible. Moving to the dark background and moving back to the light background, names become again readable. Problem is solved. Essentially color of the fonts beame initally white on a white background, characters were no more visible. Problem with SD card . After the upgrade, the SD card was recognised, with all the files in it well readable in the Data Manager . Following a phone reboot the card was no more visible in the Data Manager. Rebooting again the phone, the card became again visible. Currently no problem with SD card. Few issues with Widgets: it seems to me that few Widgets are not working well, perhaps it is a matter of learning from my side. No big issues in any case. Microsoft Apps all working, very well: I have installed Edge, OneDrive, Outlook, Office, Microsoft Weather : all work fine, very fast. WhatsApp: working very well. That is all from my side.
RAM: 6G
Rooted: No
APP Name:
66 REPLIES 66
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2019 06:03 PM
The only problem i'm having os related to memory management. It closes apps in background, alot of app reloads thst don't happen on Android pie. Aldo, the ram seens capped at 4gb. I have the 6gb Variant but It never used more than 4gb.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2019 07:04 PM
Thanks you all for sharing feedback for Android 10. This helps me to decide not to upgrade. 😞
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2019 07:05 PM
Hey,
If I update my phone using the zip in the link, will it give me problems in future updates?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2019 07:40 PM
rockingsahil.120 posted on 2019/12/4 11:05 Hey, If I update my phone using the zip in the link, will it give me problems in future updates?&nbs ...Hi rockingsahil.120, Since version 100.04.44.98 is the first upgrade from Android Pie to 10, in order to ensure the upgrade quality for each customer, we will open the FOTA for each region in stages. To ensure normal use, we would suggest that you wait for the FOTA or official link that will be released on our website. Thanks for your patience and sorry for any inconvenience this may cause.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-03-2019 10:56 PM
Jei_ASUS posted on 2019/12/4 09:10 Hi rockingsahil.120, Since version 100.04.44.98 is the first upgrade from Android Pie to 10, in o ...Hello, Thanks for the info sir. Also can I get list of region wise sequence for the update?
