01-04-2021 06:27 AM
01-04-2021 09:25 AM
01-05-2021 01:07 AM
01-06-2021 05:55 AM
Christine_ASUSThanks and we are egarly waiting! 😁Hi friends
I will check with the relevant team of ZS620KL Auto Focus in 6+ cm and Manual Focus in 10+ cm. However, I assess that it is a normal behavior because (1) the standard of the nearest focus distance is normally up to 10-15 cm (2) all the Android 10 version ZS620KL have this behavior.
I will keep you updated and your consideration will be very much appreciated.
01-06-2021 06:42 AM
ranesanket90for me AF or MF both are disabled in my 5z but GCam able to focus with wideangle camera also its an software issuePlease tell us some basic information before asking for help:
- Model Name: Asus Zenfone 5z ZS620KL
- Firmware Version: WW_100.10.107.110_20201118
- Rooted or not: No
- Frequency of Occurrence: Regular
- APP Name & APP Version (If your issue relates to the app): Asus Camera Application
The problem first started occurring after Oct or Nov security patch update. I was waiting for Asus Dev team to recognize the problem exists as many where reporting it. but Asus moderator giving stupid response go to service center.
describing Issue with camera as follows
Main camera is able to focus just fine no problem with it.
Wide Angle camera Does not Focus at all.
In Pro Mode Autofocus is disabled.
To Fixed This I have tried following instruction which are usually given by Asus Moderators or Customer Service.
- Started in Safe Mode try using camera same problem exists.
- Cleared cache memory of Asus camera application. it did not resolve problem.
- Completed factory reset it did not help.
- Completed Hard reset through recovery mode it did not help.
I have tried GCam application with it wide angle as well as main camera is able to focus. so its definitely not hardware issue its an software issue.
so now question is when will Asus Dev team solve it as its been over 2 months they are not even bothered to solve it and Sincere request to Asus Dev Team don't want to give any feature to phone even its well capable of handling its fine but don't break the phone by providing bugs. the Phone is performing so well after 2 and half year of use still I'm getting battery usage of single day. phone is still performing like a new. so please don't break it by buggy updates.
Please don't give a stupid response go to service center to solve it. it needs to be fixed under firmware update. you're damaging companies reputation by these kinds of updates.
I'm not bothered that much as main camera able to focus is not blurry able to read QR codes if it was messed up then camera will be useless.
Just fix this as soon as possible.
Lost Auto Focus (Asus Zenfone 5z) in wide angle as well as in Pro mode
