[5Z] Battery percentage not precise.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-20-2020 03:25 PM
Model Name: ZS620KL
Firmware Version: .87
Rooted or not: Non-rooted
Frequency of Occurrence: Constantly
APP Name & APP Version (If your issue relates to the app): System
I felt battery percentage holds on a number for a while and then runs out quick suddenly after moderate or heavy use, instead real-time monitoring the charge as expected.
It happens too when 100% charged, then - when unplugged - it drains the first 10% very quick.
Now, I needed to restart the device with 5%, it just turned off, didn't try to turn on again and just shown the empty battery.
Could you take a look on the sensor settings?
It seems this is a recurrent bug of the Android 10 builds on 5Z.
Already tried:
Wipe data/Factory reset (nothing changed)
Other Android 10 builds (nothing changed)
Battery calibration (nothing changed)
Downgrade to 9 (but I can't stay there because of low wi-fi signal bug and security patches)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-22-2020 03:00 AM
BrunoF20Can you please send me your reply in a PMPlease tell us some basic information before asking for help:
- Model Name: ZS620KL
- Firmware Version: .87
- Rooted or not: Non-rooted
- Frequency of Occurrence: Constantly
- APP Name & APP Version (If your issue relates to the app): System
- I felt battery percentage holds on a number for a while and then runs out quick suddenly after moderate or heavy use, instead real-time monitoring the charge as expected.
- It happens too when 100% charged, then - when unplugged - it drains the first 10% very quick.
- Now, I needed to restart the device with 5%, it just turned off, didn't try to turn on again and just shown the empty battery.
Already tried:
- Wipe data/Factory reset (nothing changed)
- Other Android 10 builds (nothing changed)
- Battery calibration (nothing changed)
- Downgrade to 9 (but I can't stay there because of low wi-fi signal bug and security patches)
Download "3C battery manager" from play store.
In the first setup screen set Android µA
Press next when asked about battery capacity
Allow 3C Battery Manager to run in the background
Set Battery data recording to record all the time with 5 seconds intervals while charging
For UI, activate History and Show mA in history
To export your battery history, go to settings, battery, export battery history.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2020 06:03 AM
Anders_ASUSFollowed steps and here are the stats please check if battery performs good at .87 latest firmware A10 shared this on behalf of brunohttps://zentalk.asus.com/en/discussion/30774/5z-battery-percentage-not-precise
Thankyou😊 @Anders_ASUS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-16-2020 11:26 PM
BrunoF20How about this ?...has been for two weeks....please someone tell me what happen to my Asus Zenfone 3 Max ..Please tell us some basic information before asking for help:
Already tried:
