2020 January Pie update major problems
HiiroNTC
ZF Model: ZE554KL
RAM: 4G
Firmware/APP Version: WW_ZE554KL_16.0620.1910.19
Frequency of Occurrence: In the last Pie update
Rooted: No
APP Name: ZenUI keyboard, system sound
I wasn't expecting a new update for Android Pie, but I was surprised to see it. Anyway, two major problems from the last beta weren't fixed. 1. When I start the device with a connected earphone, if I remove it, the system doesn't redirect the sound from the earphone to the built-in speaker. The only way to make the speaker work again is restarting the device without anything plugged in the 3.5mm slot. 2. I can't customize the keyboard. Every time I go to the custom themes and try to edit the two customizable ones, the app simply crashes and returns to the keyboard settings. If you guys won't fix that problems, at least release a downgrade again, like last time.
23 REPLIES 23
vl_rakov
Last edited by vl.rakov on 2020/1/9 06:46 I'm using lastest android 9 beta 19 version and don't have this problems. All works perfect. I think u need do wipe cache before update beta pie. Hope we will get soon official pie, i believe in you guys, just do to us new year present. 
HiiroNTC
vl.rakov posted on 2020/1/8 22:37 I'm using lastest android 9 beta 19 version and don't have this problems. All works ...
Well, great for you. Even with a cache wipe and a factory reset here, this keeps happening.
eduardomc
Henrique, você tem encontrado problemas em ouvir mensagens no WhatsApp como se fosse ligações? Aqui o sensor de proximidade bloqueia a tela e eu não consigo ouvir nada...
HiiroNTC
eduardomc posted on 2020/1/13 10:08 Henrique, você tem encontrado problemas em ouvir mensagens no WhatsApp como se fosse ligações? Aq ...
Vi aqui e tá ocorrendo a mesma coisa.
