3 weeks ago
So today, one of the reasons I sold my old phone was because of NFC issues, It would work fine the first 5 times and on the 6th it would completely malfunction and no longer read until I restart.
I got this Asus Zenfone 11 hoping it would be the end of that but to my surprise it still happened today on the TFL, NFC would no longer respond until I restarted my phone but it still occurred, I don't know if this is an android thing or if something is wrong with my motherboard but this is a literal deal breaker. Please help, I don't want to wait 1 minute to restart my phone, imagine if I miss my train because of this
Tuesday
Hey @MrMihi,
Can you please share a log for the issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
