Asus Zenphone 11 Ultra Network outage problem!
nivaar
Hi anyone facing network outage problem on Asus Zenfone 11 ultra? If yes, is it a software or hardware problem? Should I ask for replacement while I have grace period?
Mansi_ASUS
Hi @nivaar,
Can you please share the log for the issue?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Phone, mobile networks, and signal”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
