Zenfone 10 sudden battery drain
Ravain
Hello, I've recently returned to Zenfone with 10th iteration after a year break from Zenfone 8, but I see the same issues popping up.
I've left my phone on wireless charger only 5 hours ago, it was at 77% with battery settings set to stop at 80%. Now I'm waking up and there's only 13% battery left, that's serious disappointment. First day of usage I was amazed when whole day used only 55%, now I'm thinking about returning it.
Charger is Baseus 15W, but it seems to have stopped at 80% and didn't resume charging when it dropped from 80. Recently I've had some android update probably and few apps installed, including wear os + sync with my Ticwatch 3 Pro. Battery doesn't show "screen on time" at all and there's new entry at the bottom "other" with 26% of battery usage. What's strange is that it shows 3 hours ago it had 50%, but I'm sure it was 77% when I was going to sleep.
Any solutions? Screenshot attached.
Mansi_ASUS
Hey @Ravain,
Can you please share a log file?
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Hey @Mansi_ASUS
Here's the link to log file I've created just now: https://drive.google.com/file/d/1-o1ofuSzthFK0lfzqP26t1rfRG_ln_xf/view?usp=drivesdk
Or do you want me to create a log file after another night like that, collecting data during that time?
Best regards
