Zenfone 10 PowerMaster/Battery
mitchlin
When low on battery, a notification from PowerMaster is shown. However the settings cant be accessed by clicking on the settings button nor can these be found in Android Settings menu.
Mansi_ASUS
Hey @mitchlin,
It's the expected behavior. The notification always shows up, when your device is low on battery.
You can tap the "skip once" prompt on the notification or tap the notification (or Settings button) and select a different system mode to get rid of the notification.
Hi, the notification it self is not the issue. The fact that I cant select a system mode anywhere is the issue. The related settings are missing from the Settings menu. Which I assume is also why pressing Settings on the notification doesnt bring me anywhere.
