Zenfone 10 Bluetooth Audio problems
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-31-2024 08:26 AM
My Zenfone 10 apparently doesn't have a reliable connection to blue tooth headphones.
I've tried 3 sets (Sony wf-1000m5, jaba elite 10, jabra elite 7).
When the phone goes on my pocket the connectivity drops and it becomes unusable with Bluetooth headphones. Even holding the phone at arms length causes connectivity issues and constant audio drops/desync.
Holding the phone closer to my earbuds fixes the issue.
Any fixes?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-03-2024 04:00 PM
Bump until am Asus employee responds.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2024 01:10 AM
Hi @Ndonnine,
Could you please share two Bluetooth logs, one with the headphone that seems to work fine (Jabra Active Pro 7's) and the other with which you happen to be experiencing this issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “Bluetooth”
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Please share the log with me via PM.
- « Previous
- 1
- 2
- Next »
