LE Audio (LC3)
pfdang
I got my Sony WH-1000XM6's in today and was really excited to try out the LE audio, specifically auracast. Thought the zenphone is "compatible" with LE Audio, I'm not having any luck getting it to connect correctly. It tries to pair and transmits audio, but it appears to be having some trouble negotiating the LC3 codec as the audio is extremely garbled and not at the right frequency.
It's bizarre, because even though it is in this semi-connected state and is transmitting audio and communicating with the sony "sound connect" app, the bluetooth manager still just continually says "connecting". Not sure if anyone else has had any luck with LE Audio on this phone, but I'd be curious of your thoughts.
Also worth noting, the headphones worked flawlessly in LE Audio on my partners Pixel 9pro.
12 REPLIES 12
My apologies. After completing this step, please restart your phone and then re-enable LE Audio.
pfdang
This did not change the problem.
Thank you for letting me know! I'm forwarding this to the dev team.
In the meantime, could you please share a log for them to review?
To do so, enable the log tool and then recreate the issue. Once you're done, feel free to send me a DM with the link.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Could you also please share your firmware version with me? You can find it in Settings > System > About phone > Build number
pfdang
Sure thing Mattias,
WW_35.0604.0404.140
I'll grab those logs when I can get a break from work today.
