ZENBOOK PRO DUO SETUP 2 EXTERNAL PRO ART DISPLAY WITH USBC NOT WORKING
monsterfj40
System: PRODUO UX582LR
Battery or AC: AC
Model: UX582LR
Frequency of occurrence: NEW
Reset OS:
Screenshot or video:
Detailed description Trying to set up the new duo UX582LR with 2 asus pro art pa279cv with the USBC as the connection. It is not working on either of them. Tried the HDMI and it works right away. Tested each one separately, as UX582LR only has one HDMI, and they both work well WITH HDMI. But when I try with the USBC neither pro art displays will work. The USBC also doesn't work just as a peripheral connection for other mouse, mic, and keyboard plugged into the monitors.
Updated drivers as that was suggested but still no USBC to monitor working...
What i want is to setup the UX582LR with the 2 PROART PA279CV with the USBC thunderbolts for display and be able to plug things into the monitors and have the UX582lr recognize anything I plug into the monitors.
Loving the displays and the laptop but getting them all to connect with just the USBC thunderbolts is proving to be impossible.
Thank you for help and answers!!
Blake_ASUS
Community Legend II
Hi there,
May I know if you turn off the screenpad, connect 1 PA279 by HDMI and another PA279 by Type C, does it work?
Sorry I'm not sure what kind of cable are you using.
Is it Type C to DisplayPort or Type C to Type C? or there is another hub?
