ux433fn with wifi intel ac 9560 error 10
AleeeKoi
System: window 10 pro (v. 2004)
Battery or AC: both
Model: ux433fn
Frequency of occurrence: every startup
Detailed description:
Hello, I'm facing an issue with the wifi module. The hardware device stop working with an error 10.
Searching on the web I found a temporally solution: resetting bios setting on defaults. But on every new startup the problem return and the wifi stop to work.
Using the driver linked on the official asus page or update it to the last provided by intel doesn't resolves the problem.
Uninstalling wifi driver and reinstall it making a clean installation is not working too.
There are any solutiions?
Thank you
18 REPLIES 18
Blake_ASUS
Community Legend II
Hello AleeeKoi,
Does the issue happen in 2004 only? or also in 1909?
AleeeKoi
Hi, I’m not sure but I think it’s not related to the os version. First time append ~ 4 month ago and resetting bios makes it working again.
Now it’s impossible to use.. every day I need to reset bios to default.
there’s something can I do?
RAJU_MSC_MATHEM
Zen Master I
AleeeKoi
Try to use generic wifi driver from intel site for your model.
or esle some other barnds laptop might use same wifi device with customized driver , so install that driver if you able to find it,
AleeeKoi
RAJU.MSC.MATHEMATICS
https://zentalk.asus.com/en/discussion/comment/105092#Comment_105092
it’s my second topic on this forum and it’s your second response without reading what I have just written........
Drivers from intel Website are not working.
And no, I don’t want to search in others web sites for a solutions..
