UCM-UCSI ACPI Device - (Code 43)
JBennett360
System: Windows 10
Battery or AC: Both
Model: Zenbook UX325EA
Frequency of occurrence: Always
Reset OS: Yes
Screenshot or video:
Detailed description:
Reset the PC and kept my files. Used the option of a local install so that the asus apps would remain on the system too.
Everything seems to work okay, except for that error message thats displaying in the windows device manager.
All USB ports seem to work?
Does anyone have any ideas at all?
7 REPLIES 7
JBennett360
This is the issue I currently have.
RAJU_MSC_MATHEM
Zen Master I
JBennett360
are you trying connectr USB acpi device through usb port, Is thatdevice comes with driver CD , if then means install driver .
see below website , follow the steps
UCM-UCSI ACPI Client - Windows 10 Service - batcmd.com
JBennett360
RAJU.MSC.MATHEMATICS
https://zentalk.asus.com/en/discussion/comment/144073#Comment_144073
Had nothing connected except for the charger.
Turned off the PC went into bios. Reset to default. Save rebooted and it seems to be sorted?
Will see how it goes.
RAJU_MSC_MATHEM
Zen Master I
JBennett360
https://zentalk.asus.com/en/discussion/comment/144105#Comment_144105
problem solved or not.
why did you connected charger via USB.
is there is no dc charger slot in your laptop?
