Need help, HDMI port does not use Nvidia Mx250 but intel UHD, trying to run 5120x1440 DUOux481FL
Seevip2
System: Asus Zenbook Duo UX481FL
Battery or AC:
Model:
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:Hi Everyone,
I have to manually reconnect the HDMI cable when the computer restarts to ensure I get 5120x1440 working (only at 29hz)
Otherwise the computer will start at a random resolution that is 1080 or 4k. It is strange that it changes all of the time.
Even when I am running it at 5120x1440 it is using Intel UHD, how can I change this to Nvidia MX250?
Thanks
Blake_ASUS
Community Legend II
Hello Seevip2,
The maximum resolution and frequency that the HDMI on this device exports is 1920x1080 @ 60Hz,
and it is using the Intel VGA card to export.
RAJU_MSC_MATHEM
Zen Master I
Seevip2
  1. System: Asus Zenbook Duo UX481FL
  2. Battery or AC:
  3. Model:
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
Thanks
in laptop, you cannot change dedicated gpu for external display.
by the intel processor manufacturing limitations applied and stored in processor
