08-06-2019
04:13 AM
- last edited on
01-16-2024
12:42 AM
by
ZenBot
08-13-2019 02:07 AM
08-14-2019 01:06 AM
Jei_ASUS posted on 2019/8/13 10:07 Hi Koudmaker, Thanks for your feedback.I notice it by noise of the fan speed. I Think when the phone is on auto mode on the home screen is the same speed. Turning on a Game running max settings its still running on the same speed will the phone is getting hotter. I think they should at a setting that will increased the fan speed to max i've the phone is hitting 40c or higher.
08-16-2019 02:06 AM
Koudmaker posted on 2019/8/14 16:06 I notice it by noise of the fan speed. I Think when the phone is on auto mode on the home screen i ...Hi Koudmaker, Thanks for your reply. Could you tell us when the temperature comes to 40 degrees in auto mode, is the fan speed lower than/ higher than/ the same as the maximum fan speed when adjusted manually? Thank you 🙂
08-16-2019 04:27 PM
Jei_ASUS posted on 2019/8/16 10:06 Hi Koudmaker, Thanks for your reply.The fan speed is way lower in automode when reaching 40+ degrees so i have to turn it to manual mode to hit the max speed of the fan. I know why the fan speed is lower because of the noise of the fan when its manual set to maximum but when a phone hits 40+ degrees the fan should kick in at max speed to reduce the heat and cool the back of the phone more.
