11-17-2019 06:02 AM
11-17-2019 06:49 AM
11-17-2019 11:41 AM
11-18-2019 07:44 AM
11-18-2019 07:57 AM
Anders_ASUSHey man ,i have seen a lot of other guys post the same ss which showed it to be enabled and i am pretty sure thats the problem with the device and yes i have my enhanced 4g lte mode enabled.Not only that after every 5 10 mins my wifi automatically reconnects itself idk whats the issue regarding that,i hope you can help me outHi @Shreyash the menu where you just looked is not where you enable VoLTE. It's supposed to be grey.
When you look in settings -> network & internet -> Mobile network. Do you have Enhanced 4G LTE Mode enabled?
