ROG Phone 2 problem with site access
nannyflip
Hello everyone, I’m very pleased with the phone, I really like Gorilla Glass and all games work stably. But I have some kind of bug, I can’t access some sites after the April security update. Has anyone encountered such a problem?
9 REPLIES 9
Gustav_ASUS
Community Legend III
@nannyflip Are you using Chrome? In that case, try opening the same websites from your PC using Chrome and see if you can connect. Also check if you can connect to the websites you've listed by using an Incognito tab on your phone.
Also, it it happening when using wi-fi, mobile data or both?
nannyflip
Thanks for the advice, the situation is as follows: I was able to access this sites: https://www.tripoto.com/, https://www.hometalk.com through incognito and wifi mode, these sites: https://www.deezer.com/ru/ showed a certificate error. Through the mobile network, this sites do not open at all and I noticed that some applications stopped opening.
I think to take the phone to a service center.
catox69052
same problem I recently purchased a used ROG Phone 2 and some websites will not open even though I have enabled third-party cookies and done a factory reset, especially my website: https://zaubee.com I tried top websites like https://www.iheart.com and many more.
exodusthr
I wonder if anyone has solved this problem? I can't access local directory sites including https://us.weloob.com for some strange reason. Is it because there is too much content on such sites?
Hi @exodusthr
Do these sites open for you on a separate mobile device? The issue could very well be the site and not your actual ROG phone.
