07-18-2020 09:57 PM
07-22-2020 07:24 AM
adityathorat99What happens if you used a charger that did work and play games? Does it restart then?https://zentalk.asus.com/en/discussion/comment/98222#Comment_98222
This issue started after the system update. And I've noticed one thing that whenever i start any game it restarts fr 2 to 3 times simultaneously, also when I connect it to the charger it does the same. I've tried new ROG 2 charger but same thing happens but, if i use another non Asus charger it works fine. Before the update it was running very very smooth now i cant even open whatsapp while its charging or play any game at any time. Tell me what should I do..?
07-22-2020 09:05 AM
ronald1985Yes it does. The other charger only helps it to keep charging without restarting. But if you start any game , then it restarts and heats up.https://zentalk.asus.com/en/discussion/comment/98429#Comment_98429
07-22-2020 10:51 PM
ronald1985I am also facing the same issue along with the so many users.https://zentalk.asus.com/en/discussion/comment/98429#Comment_98429
07-23-2020 10:20 PM
psgbharathiNot a single person from the Asus Team has Responded.. what the hell..!! I am thinking of selling my phone. In just three months this is the situation..!!!https://zentalk.asus.com/en/discussion/comment/98430#Comment_98430
Believe me I have tried factor reset thrice, downgraded to all the stable version of A10 and reverted back to A9.
There is no help at all, it will restart or black screen whenever I play games or do heavy thing. But it's only happening if I use phone while charging.
It's so frustrating I can't even use the wtsapp.
Like zenfone6 update.167, Rog2 A10 update triggered malfunctioning of the motherboard I believe.
Take your device service center.
I have to do tht also once I reach my home country India.
07-24-2020 02:40 AM
adityathorat99There's plenty of post about this issue, that has a response from ASUS.https://zentalk.asus.com/en/discussion/comment/98615#Comment_98615
