ROG 2 - Is there any safety regarding water splash
RAIDEN_
Rising Star II
So considering the big vent on the backside of Rog 2 , will the device survive if the water gets inside through the vent ? Is there any safe mechanism Asus did to prevent such ?
13 REPLIES 13
duy_h_vu
Rising Star I
He dunk the phone in water for 2 mins and it still work (6:45). Should you do it? NO. But if acidental drop in water or splashed then there's a good change phone can be save. Turn the phone off the put it in dry eviroment. Even my s8+ with IP rating suffered mosture damaged and it was out of warranty so for me there's no phone is safe to use in high humid environment for a long period of time, especially charging does speed up the corrosion. Cheer.
https://youtu.be/UFXvF0sM-Xs
OPC
Zen Master II
Good news duy! Not being IP rated was a compromise I was willing to take. It's even better it survives.
NemoJr
Anders_ASUS
We do not recommend using ROG Phone II during a water fight. It would probably survive some minor splash but there's no guarantee. Minor rain shouldn't be a problem but if the water indicators inside are colored when we open it up, then the warranty is voided.
Bro is there a water damage indicator inside ROG PHONE II Global Variant???
ronald1985
Community Legend I
NemoNeymarJR
https://zentalk.asus.com/en/discussion/comment/22363#Comment_22363
You should assume there is one considering the phone is not water resistant/proof due to the vents, charging ports and earphone jack. This is a way to protect the company from false accusations that the phone doesn't work but it was actually dropped in the water and dried up.
NemoJr
ronald1985
https://zentalk.asus.com/en/discussion/comment/91964#Comment_91964
Means? I just want to know if i dropped it in water and fully dried it up, will the service center guys know that the phone was dead because of water??
