Pubg network problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-25-2020 06:19 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2020 09:26 AM
ungkufarid93Can you go to Settings - System - Reset Options and perform Reset, mobile & Bluetooth.Help me guys. Im playing PUBG from my ROG phone II. My PUBG keeps on disconnecting in the middle of the game which really annoys me. I have more than enough mobile data to run that game. Everytime i launch the pubg app my network suddenly changed from 4G+ to H. Then when i exit the game, my network returns to 4G again like normal. This happens with PUBG only. I do not encounter this sort of problem with another apps. Only PUBG. Keeps on disconnecting me when i launch it/or even in the middle of the game.
If you're using high quality graphics and high frame rate in PUBG, I would recommend turning these into lower settings and see if it makes a difference.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2020 10:19 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2020 10:25 PM
ungkufarid93Thats your network provider issue..Help me guys. Im playing PUBG from my ROG phone II. My PUBG keeps on disconnecting in the middle of the game which really annoys me. I have more than enough mobile data to run that game. Everytime i launch the pubg app my network suddenly changed from 4G+ to H. Then when i exit the game, my network returns to 4G again like normal. This happens with PUBG only. I do not encounter this sort of problem with another apps. Only PUBG. Keeps on disconnecting me when i launch it/or even in the middle of the game.
Things u can do here :-
In dialer dial #*#4636#*# , which will open up a window ..
There u need to select LTE only to avoid that network switching..
Second thing u can additionally do here is restrict background sync in armoury crate for Pubgm
Do note ping on mobile data is not stable , so its always recommended to get a wifi connection instead ..like i have 50Mbps wifi connection and my ping never goes above of 50ms
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-25-2020 10:34 PM
