Problem with right Air Trigger
gonzaaa_92
Rising Star II
Hey!
So I'm having a problem with the right Air Trigger of my ROG 2. What happens is that it has some sensibility issues, sometimes you press it and it flickers. Something I noticed and this only happens with the right AirTrigger is that if you force press it, it stops from working. Whats going on?
Thanks!
60 REPLIES 60
imkara92
same issue for me as well. i read all of the comments and i can say that the problem is pretty much the same. left air trigger works well but the right one flickers for the most users. i've been using this phone like 7 months. it's been a while since the latest update, so i do not think that it's related to the update issue. it suddenly started just a few days ago. i also formatted the phone but the problem is still active. i cleared the surface of the buttons, tried sensitivity booster etc... nothing works... it makes me extremely annoying because i've been using it for 7 months in FPS games. and because of that i used to it, it's a big problem for me... i hope it'll be solved otherwise my next phone will not be an Asus. And please let me know if any of you guys find a solution.
Edit: i just added the video of it. as you can see in the video, the left air trigger is completely fine when i move my fingers on the surface. but the right one flickers all the time. the result is the same if i hold my fingers on the right air trigger.
yosef019
Rising Star II
i have same problem with left trigger !
bought from B&H 512/12 GB
Middle section of left air trigger have this problem
marvinloya26
This is a general issue after android 10 update. Why wont asus fix this?
itsjacu
Same issue here. The right air trigger flickers. Even with sensitivity booster , the same problem persists.
imkara92
@Gustav_ASUS is it a software or hardware related problem? These air trigger flickering problems, i mean.
