Powermaster Help please
ishaan_gupta10
Powermaster is terminating my app in background even after I have disabled all the settings. Even I have set app' battery optimisation to 'not optimised' . Attaching some snapshots of the settings. Please help me and tell if there are more settings i need to do. Its really annoying.
14 REPLIES 14
ronald1985
Community Legend I
ishaan.gupta10
Just a kind note, your screen timeout is 2 minutes. You need to becareful in not setting your brightness too high, otherwise you will get screen burn.
Back on to the topic, what app is causing you the problem?
Can you show a screenshot of it being "not optimised" please?
ishaan_gupta10
mapmyride.
ronald1985
Community Legend I
ishaan.gupta10
mapmyride.
Is it while you have it open and then it shuts itself down?
Is it possible you can do a screen recorder of the issue? I will give it a try too.
ronald1985
Community Legend I
ronald1985
https://zentalk.asus.com/en/discussion/comment/107043#Comment_107043
Hello,
Just to let you know I have managed to install the app and I have managed to have it running when the phone is on for 40+ minutes as I was using Google Maps too.
I will try it with the screen turned off to see if I can get the same issue as you and let you know.
I have Battery Optimisation off like you do, but I do have Detect Battery Draining App turned on where you have it off.
If you can give more information about the symptoms of the problems, that would be helpful too.
