03-23-2020
11:44 AM
- last edited on
01-16-2024
01:30 AM
by
ZenBot
03-27-2020 06:50 AM
xtomyleeThey have fixed some of the issues, like notification bugs, but produced new bugs.I can confirm that apps are being killed no mater what. Turned off all possible battery savers, optimisations and managers.. that's kinda sux. Ui feels laggy, battery doesn't lasts any longer compared to Android 9. No new features at all. At least I didn't noticed. So basically useless update.
03-27-2020 07:27 AM
03-31-2020 02:32 PM
SourabhYou're not supposed to have a lot of free ram. Best case scenario is when it's almost full. If not, then you have RAM sitting around doing nothing. Android isn't Windows. They use RAM differently.worst update for Rog 2. Only 3 gb ram is free even force closing all the apps.. games lagging...battery draining like running nose...
03-31-2020 02:35 PM
xtomyleeAndroid 10 might not be Googles coolest update but it has a couple of good under the hood changes fixes. One useful fix that you might like is built in playstation dualshock 4 supportI can confirm that apps are being killed no mater what. Turned off all possible battery savers, optimisations and managers.. that's kinda sux. Ui feels laggy, battery doesn't lasts any longer compared to Android 9. No new features at all. At least I didn't noticed. So basically useless update.
