High temperature / CPU usage / battery drain on 2009.47
jasonwch
Rising Star II
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
As many posted on the forum. I and everyone have similar issue. (This is already upgraded for whole night and a full charge)
CPU also peak at 2.84/2.96 as from Armoury Crate even didn't do anything
Temperature goes high
Battery drain quickly
"Android System" also taking all battery usage from Battery page
What I observed:
From running processes, "Google Play Service" always show up, which not the case in old firmware
What I've tried to fix:
Wipe data (all data not just cache) for Google Play service and Armoury Crate. After cleaned, seems the CPU back to 826Hz, but after I restart the device, it go back to 2.84/2.96 all the time
There may be something wrong on this?
266 REPLIES 266
Daulat
Rising Star II
ronald1985
Ok, might as well try this. What you do below wont clear anything so you are good to do this without worrying about losing anything.
  • Go to settings - apps - show system apps
  • Go to Google Play Services - Head over to storage and clear both data and cache. You dont lose anything here.
  • Go to Armoury Crate and do Clear Cache only
  • Now go to settings - Battery - Power Master - Battery Saving Options
  • Tick Clean Up Suspend.
  • Restart the device.
This doesnt fix the issue at all. It is a workaround so your device doesnt go mad at full speed and heating up.
Do post back of it works so it helps moderators here to pass this back to Dev.
This worked i guess.
I cleaned data for play service and armoury crate and now it's fine
Temperature are low and its people 800mhz as well.
Will post if something went wrong.
But thanks
Daulat
Rising Star II
nationkid
  1. Model Name:
  2. Firmware Version:
  3. Rooted or not:
  4. Frequency of Occurrence:
Since the latest update I'm these temps, side of the phone is really hot. Live in the uk so ambient temperature ain't the cause.
high temps while watching youtube or idle
Try this my temperature and cpu usage is normal now and have more battery time like 3hr boost
Daulat
Rising Star II
@ronald1985 thanks mate
jasonwch
Rising Star II
jasonwch
Updated Google Playstore 21.9.50 from APKMIRROR. Restarted the phone, CPU no spiking. Did once "Check for update" from Playstore but DIDN'T update the app pending, still no spiking.
I will check again after an hour, if still no spiking, will try to update that pending app and see if CPU spikes again
CPU keep normal UNTIL i click "update" on that pending update app. CPU sticks at 2.96Ghz again
jasonwch
Rising Star II
17daulat
https://zentalk.asus.com/en/discussion/36258/high-temps-while-watching-youtube-or-idle
i did this clean Armory crate and play service trick
It works UNTIL i click update on app from Google playstore
you can try to search for update from Playstore, then update it, it will back to full CPU again
Thanks
