High temperature / CPU usage / battery drain on 2009.47
jasonwch
Rising Star II
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
As many posted on the forum. I and everyone have similar issue. (This is already upgraded for whole night and a full charge)
CPU also peak at 2.84/2.96 as from Armoury Crate even didn't do anything
Temperature goes high
Battery drain quickly
"Android System" also taking all battery usage from Battery page
What I observed:
From running processes, "Google Play Service" always show up, which not the case in old firmware
What I've tried to fix:
Wipe data (all data not just cache) for Google Play service and Armoury Crate. After cleaned, seems the CPU back to 826Hz, but after I restart the device, it go back to 2.84/2.96 all the time
There may be something wrong on this?
266 REPLIES 266
Sourabh
Rising Star I
No..its working for me even after clearing cache memory. My phone is heating. Was planning to upgrade to rog 3 but not interested now as i dont want to waste money on the same problems.. dropping refresh rate, heating issues
jasonwch
Rising Star II
Sourabh
you may need to read through this thread. @FiREPLAY suggested ADB method, or my suggested killing FOTAService also can be a workaround until next FOTA in coming week
oby_90
download the 2007 A10 firmware file, then rename the 17.xxx to 18.xx. Place it to root folder the reboot the device.. it will detect the firmware cz it reads the file to be newer than the existing firmware.
do this with you own accord, i'm not responsible for anything that will happen with you device. this is what i do (ps. your data will be wipe)
Melqui
Zen Master I
oby_90
I tried this. Don't works.
IRONHIDE
Rising Star II
nationkid
This is a tricky one also. I have contacted support in the hopes of a fix or some form of resolution because I cant use my phone really, its constantly hot and causing it to restart or the battery only lasts 4 hours if fully charged.
Support are telling me to do a full factory wipe/reset which I think is so stupid. It's not going to fix the issue at all.
it wont work tried it.
