High temperature / CPU usage / battery drain on 2009.47
jasonwch
Rising Star II
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
As many posted on the forum. I and everyone have similar issue. (This is already upgraded for whole night and a full charge)
CPU also peak at 2.84/2.96 as from Armoury Crate even didn't do anything
Temperature goes high
Battery drain quickly
"Android System" also taking all battery usage from Battery page
What I observed:
From running processes, "Google Play Service" always show up, which not the case in old firmware
What I've tried to fix:
Wipe data (all data not just cache) for Google Play service and Armoury Crate. After cleaned, seems the CPU back to 826Hz, but after I restart the device, it go back to 2.84/2.96 all the time
There may be something wrong on this?
266 REPLIES 266
igor-mn
Friends. Stop FOTA service. Just do that and everything will be OK. Thanks.
kerainsakurai
The main culprit is the google playstore
Not applicable
kerainsakurai
It's not, it happened after asus's latest update which ruined everything. A9 is giving me more battery life, less bugs and less headaches. I am thinking of sticking to A9 because its super smooth and not many bugs! Shifting to A9 was probably a good call!
Sourabh
Rising Star I
Yes...i cant use my phone due to that heat... Even when using normal lite apps..
Melqui
Zen Master I
jasonwch
https://zentalk.asus.com/en/discussion/comment/117425#Comment_117425
you can still do the installation, but after install apps(APK or playstore), trigger FOTAService(check for system updtae) then kill that process again from developer options -> running process
The problem is that "Google Play Services" and "Google Play" install themselves.
