12-05-2019 07:10 PM
Solved! Go to Solution.
04-25-2020 08:22 AM
OPCI know it, but that feature can be solution for this case 🙂https://zentalk.asus.com/en/discussion/comment/74626#Comment_74626
Roaming means that if you go to another country you can use your phone on foreign networks.
